Installaware 9 - pin to taskbar, startmenu
Re: Installaware 9 - pin to taskbar, startmenu
Postby michaels » Tue May 08, 2012 10:35 am
I tried that same installer (demo.exe) on several Windows 7 computers on our domain and it wouldn't pin on any of them, nor did it show the pin options on the shortcut. Interestingly enough, I tried it on Windows 8 and it worked fine. With UAC off it still did not work on Windows 7 so I'm guessing at this point it may have something to do with security software or something along those lines as that is the only common application on the tested Windows 7 computers. Even run as Administrator, it still does not work, so it's possible the security software or domain settings are preventing the creation of the pin option.
I'll have to do further testing and will let you know what I find so you can pass it along to future customers.
michaels
Postby FrancescoT » Tue May 08, 2012 11:33 am
Dear Michaels,
I used IA 2012 to test it.
If you want you could download our trial to verify if it is a version issue.
InstallAware Software Support
Postby michaels » Tue May 08, 2012 11:40 am
I tried that version already as well. I think it must have something to do with policy settings on the domain.
I removed all security and rebooted, still didn't work.
I installed it on the server and the pin options showed up fine and it pinned to the taskbar.
However, on any Win 7 workstation it won't pin the first shortcut, only the second. I would bet at this point it's a permission/policy issue of some sort.....no idea what the solution is though. Will have to go through trial and error to figure it out.
Thanks for the suggestion.
michaels
Postby michaels » Mon Nov 05, 2012 12:34 pm
I found the solution to this problem after many hours of troubleshooting.
If you have a project named 'Test Demo' and another project named 'Test', and each project has 2 shorcuts (e.g. Test and Other) you cannot install the Test project after Test Demo project on the same computer otherwise pinning will fail on the first shortcut and the pin to taskbar options will not work. You have to delete the first instance of the registry entry named 'test' under applications in the registry to fix it, otherwise pinning is permanently broken.
The solution is just to name your projects with unique names if there is a space between the project names (e.g. ESILAW Demo and ESILAW Newsite, not ESILAW and ESILAW Demo). Registry seems to get buggered up if you do this and pinning no longer works on any future installations with those names.
michaels
Postby FrancescoT » Mon Nov 05, 2012 1:49 pm
Dear Michaels,
many thanks for sharing this.
Previous
Return to Technical Support
Users browsing this forum: No registered users and 5 guests
