Hi
We are developing a Win32 project on C++Builder XE2 IDE. The development box is a Windows7 64bits.
We have tested the installation product in a Windows 7 box and also in a XP box. In both cases, no errors at all are reported during the installation process.
When running the app on the Windows 7 box, everything is working ok. However when we try to run the app on the XP box we are getting the error below:
"The procedure entry point __CxxFrameHandler3 could not be located in the dynamic link library msvcrt.dll"
Do you have any ideas what could be happening?
Note: The XP box is running Service Pack 3
Thx
Javier
Problems installing on Windows XP
Re: Problems installing on Windows XP
just to verify that I have not missed your question.
the error you reported appares during setup execution or when you launch your app?
Let me know
Let me know
When I launch the application on the XP box
Dear Javier,
in this case I can'n help you because it is not a question related to InstallAware product.
You should verify what your code exactly does.
Hi Francesco
I understand, I was just wondering if you have seen this error reported before.
Thanks for your help
Javier
Javier
Users browsing this forum: No registered users and 23 guests
