To InstallAware
I am trying to work out how to remove support files at buildtime. My main reason is when we build patches to exclude certain files to allow the patch size to be smaller.
In my project script I have added the following code to check for the patch:
[Compiler if Variable BUILDMORE Equals PATCH]
I'm not sure what line to add next to exclude the support file? Delete files I see (with ref to the help file) removes the files during installation.
Any help would be appriciated.
Thank you,
Derrick
