undo option in Dialog Editor
Re: undo option in Dialog Editor
Postby ckaware » Wed May 09, 2012 10:14 am
kishorkk23 wrote:Hi, I have added a next button in the progress bar, I gave the option false in the dialog.
Now that I want the button to be completely removed. But once I made it false, I am not able to click on it..
How Can I remove it?
I have attached the snapshot
This is a problem with the editor, if you "Disable" a button for example, you cannot select it without MOVING the panel/ image or object on top of it.
ckaware
Postby FrancescoT » Wed May 09, 2012 12:00 pm
Have tried using the TAB key to navigate within dialog controls :roll:
InstallAware Software Support
Previous
Return to Technical Support
Users browsing this forum: Google [Bot] and 4 guests
