Hello
I have now upgraded to IA11 and tried to build a new setup package of my project including Install Net Framework 4
I have selected Framework 4 and Framework 4 (64bit) in the design tab
I have uncheck both Framework 4 Client Profile because we do not need the Client Profile (we need full)
Then after build and installation at a Server 2008 R2 64bit the wizarde try to install Framework 4 but at beginning I have the error
"Error occurred while initializing fusion"
Installation fails
any idea?
regards
Hansjoerg
IA 11 Framework 4 64bit
Re: IA 11 Framework 4 64bit
Hansjoerg,
Please try running the binaries from the runtimes\net4..... folder on the target machine and see what it says - there could be an incompatibility of sorts and only running the binaries that IA is running manually can reveal the real error.
Aviv
I have found out what happens.
First I tried to include only the net4setup (Framework 4 full) without the Client profile
After build this caused the described error.
After googling a lot I saw similar errors. Some people wrote that the Client profile is always needs to install bevor the full version
So I have added the Framework 4 Client Profile also to my project, build new Setup and installed on Server 2008 R2
And no error
Framework 4 was installed fine.
It seems that we need to include both, Client and Full Profile in IA
regards
Hansjoerg
And no error
regards
Hansjoerg
Great - thanks for sharing.
Users browsing this forum: JohnGaver and 61 guests
