I am finding installers created with InstallAware Studio Admin 9.06 leave behind a LARGE temp folder when the install is done. The temp folder is a subfolder of the user's TEMP path, and begins with the letters "mia". I believe this is the $SUPPORTDIR$, which holds copies of files extracted from the installer.
Installers created with previous versions of InstallAware seemed to leave behind a similar folder; however, by the time the installation finished, this temp folder was empty (or nearly so).
I have compiler variable CACHESOURCES=TRUE, and my installers are compressed, web-based EXE's.
BTW, the temp mia folder is IN ADDITION TO the cached installer folder, which I have opted to place under the C:\\WINDOWS\\INSTALLER folder. Though these two folders may serve two purposes, they appear to contain mostly similar content.
I am considering having my installer do a RECURSIVE DELETE FILES on the temp mia folder after APPLY INSTALL completes successfully; however, I am concerned about files possibly still being open.
Does anyone have any other suggestions for the reclaiming disk space taken by this temp folder?
Large TEMP folder after install
Users browsing this forum: Google [Bot] and 61 guests
