Check Process and Terminate it if it's running
swarovski
Postby swarovski » Thu Nov 15, 2007 11:32 pm
Gizm0 wrote:Ok, it looks like a cookie issue.
Instead of browsing to forums from www.installaware.com/forum/, browse to http://forums.installaware.com and login from there (you'll probably be redirected to installaware.com/forum again, but if you browse back to forums.installaware.com, you're already logged in). Navigate here to this thread and try to download again.
It will work now.
Oh yeah!
It works. I followed exactly.
Thanks Gimz0 XD
jps
Postby jps » Fri May 02, 2008 4:32 pm
could someone tell me how to utilize this mia file, pls? it can't be opened in IA.
Thx
wlwshangBigBear
Re:
Postby wlwshangBigBear » Fri Jul 11, 2014 9:24 am
Instead of browsing to forums from http://www.installaware.com/forum/, browse to http://forums.installaware.com and login from there (you'll probably be redirected to installaware.com/forum again, but if you browse back to forums.installaware.com, you're already logged in). Navigate here to this thread and try to download again.
It will work now.
It does not work and can not be downloaded.
Re: Check Process and Terminate it if it's running
Postby FrancescoT » Fri Jul 11, 2014 10:52 am
it is an old post and probably, it has been removed by the user.
wlwshangBigBear
Re:
Postby wlwshangBigBear » Fri Jul 11, 2014 3:51 pm
SynthaxError wrote:thank's a lot for this script, i change PROCESS_NAME and PROGRAM_TITLE but it don't work in windows vista
Set Variable MSGBOX to
Set Variable PROGRAM_TITLE to WinZip Executable
Set Persistent Variable PROCESS_NAME to WZQKPICK.EXE
Check for Process "$PROCESS_NAME$", get result into variable RUNNING
if Variable RUNNING Equals TRUE
 MessageBox: Terminate Process, The process $PROCESS_NAME$ is running and it will be terminated in order to continue the installation.$NEWLINE$Please save your work and then click OK.$NEWLINE$Click Cancel if you want to continue without terminating the process.
 if Variable MSGBOX Equals OK
   Terminate Program $PROGRAM_TITLE$
any way, thank u for answering. is there some guys who could help me related to this topic. I have the similar problem, after I add several lines like above codes. I did some tests, at first installation, the application is installing, absolutely and then installaware detect the process running background, and then that message box is popped. but it is first time I try to install, so this logic does not make sense. any comments, welcome. thanks in advance
wlwshangBigBear
Postby wlwshangBigBear » Mon Jul 14, 2014 10:05 am
Hi Guys,
Could I detect whether the application which has the same name with what I want to install is running on the computer as soon as I launch and install the same installer with the higher version?
So far, I tried several ways. unfortunately, It can not work. as soon as I launch the installer and want to install it. does not matter whether the application is running, the install always popup messagebox and inform me the application is running.
what I added as the previous post shown.
any guys could help me? thanks a lot
Postby FrancescoT » Mon Jul 14, 2014 11:34 am
I just checked both "Check and Terminate" process commands ... and both work fine.
BTW, I released a simple project to test such functionality that (... see attachment).
To use it, leave Notepad.exe running while executing the setup package, otherwise the Message-Box used as confirmation for the process termination, it will be not displayed.
TerminateProcess.rar
(2.13 MiB) Downloaded 1165 times
Return to “Sample Scripts”
