I am just in the process of evaluating InstallAware as a replacement for our current Wise install system. One of the things that we require is to be able to Push install our application using the standard Microsoft Group Policy installer.
Is this possible using InstallAware, as I know that it is not possible to run the msi directly?
All help is greatfully received.
Push Installs from Group Policy
Further Information
Thanks Sinan, Have just spotted this option,
I have found a couple of issues with it though,
1) If you run the msi manually it pops up the Language Selection Dialog, is there anyway to suppress this for these installs.
2) Is it possible to use the same msi for both admin (silent) installs and normal manual installs
3) We are running a number of additional installs from this main install, but these do not seem to get run when using this admin msi. The installs are additional Install Aware created installs, I did originally plan to use the Install MSI plugin, but this did not seem to work correctly, so I have used the run .exe with the /s option
Thanks for the help.
Users browsing this forum: No registered users and 105 guests
