Error using miabuild.exe with MSBuild & Task Scheduler
kwco
Postby kwco » Thu May 28, 2009 11:18 am
I am having a slight problem with InstallAware 9 on my Windows Server 2008 build machine.
I run the command line build (miabuild.exe) from an Exec task in an MS Build Script. The installer aware script basically just grabs a few redistributable files from the Visual Studio 9 directory.
<?xml version="1.0" encoding="utf-8"?>
<Project xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
    <PropertyGroup>
        <InstallAwareDir>C:\\Program Files\\InstallAware\\InstallAware 9</InstallAwareDir>
        <IAProjectFile>E:\\IA9Test\\BuildTest\\BuildTest.mpr</IAProjectFile>
        <OutDir>E:\\IA9Test\\Output</OutDir>
        <WorkingDir>C:\\Program Files\\Microsoft Visual Studio 9.0</WorkingDir>
    </PropertyGroup>
    <Target Name="BuilIA9">
        <Message Text="Creating Installer"/>
        <RemoveDir Directories="$(OutDir)" ContinueOnError="true"/>
        <MakeDir Directories="$(OutDir)"/>
        <Exec Command="&quot;$(InstallAwareDir)\\miabuild.exe&quot; &quot;$(IAProjectFile)&quot; /r /o=&quot;$(OutDir)&quot;" WorkingDirectory="$(WorkingDir)"/>
    </Target>
</Project>
The build script is called from from a batch file like so:
SET MY_DIR=E:\\IA9Test
"C:\\WINDOWS\\Microsoft.NET\\Framework\\v3.5\\msbuild.exe" /l:FileLogger,Microsoft.Build.Engine;logfile=IA9Test.log /toolsversion:3.5 %MY_DIR%\\IA9Build.xml"
If i run this batch file from the command line everything works. But if I run it from the Windows 2008 task scheduler I get the following error:
C:\\Program Files\\InstallAware\\InstallAware 9\\miabuild.exe" "E:\\IA9Test\\BuildTest\\BuildTest.mpr" /r /o="E:\\IA9Test\\Output"
InstallAware Command Line Build Utility
EXEC : error : Not implemented
E:\\IA9Test\\IA9Build.xml(19,9): error MSB3073: The command ""C:\\Program Files\\InstallAware\\InstallAware 9\\miabuild.exe" "E:\\IA9Test\\BuildTest\\BuildTest.mpr" /r /o="E:\\IA9Test\\Output"" exited with code 3.
So why does the batch file and build sruipt succeed when run from the command prompt, but not when run from the Windows Server 2008 Scheduled Tasks manager?
Also this woked with InstallAware 8. The problem has occurred only with InstallAware 9.
ALive
Postby ALive » Thu May 28, 2009 12:16 pm
Hi!
I've encountered the same, but we're using TeamCity and Ant Build
I've written this in the post:
Error running miabuild.exe from automation build tool
http://www.installaware.com/forums/viewtopic.php?t=4649
On version 8 it was fine, but on version 9 it doesn't.
So now it's both of us :)
kwco
Postby kwco » Thu May 28, 2009 12:29 pm
Good to know it isn't just me. Hope someone can come up with a fix soon, my daily build is failing every day.
Postby MichaelNesmith » Thu May 28, 2009 12:46 pm
You need to specify correct startup folder for miabuild.exe.
kwco
Postby kwco » Thu May 28, 2009 1:16 pm
Is there a new working directory?
The WorkingDirectory is the startup folder which I set to the folder containing the files for the installer (c:\\Program Files\\Microsoft Visual Stidio 9).
This is the exact same arrangement (in fact the exact same build script) that I used with version 8.
Also this works from the command line when run from within the Directory the xml file is in. The Win2008 task uses this directory as it's "Start In" folder.
From the other thread on this issue it seems the problem is with the fact that Version 9 needs to run as an interactive desktop process (and fails with an unhandled exception when run from the task scheduler), whereas Version 8 did not require this.
Postby MichaelNesmith » Thu May 28, 2009 3:13 pm
Yes, that is probably the reason - just enable that setting in your task scheduler.
kwco
Postby kwco » Thu May 28, 2009 4:21 pm
Any Idea how to do this?
I can't find a setting like that in the Windows 2008 Task Scheduler.
It does not appear as one of the properties of a task, unless the task scheduler uses some obscure name for it.
Postby MichaelNesmith » Thu May 28, 2009 6:45 pm
Its in task properties!
kwco
Postby kwco » Fri May 29, 2009 11:09 am
In Windows 2008 Server the feature that allows a service to interact with the desktop has been removed (it's the same in Vista as well). You need to set the task to only run when the user is logged on.
This will mean leaving that user account permanently logged into the machine 24x7 so the builds can run.
dmostert
Postby dmostert » Mon Jun 01, 2009 6:14 am
Will this be fixed in a future update?
I now have to run my CruiseControl.NET as a console app i.s.o a service.
D.
kwco
Postby kwco » Mon Jun 01, 2009 9:12 am
From what I understand, after lodging a support incident, this behavior occurs by design.
danvy
Postby danvy » Fri Jun 05, 2009 1:29 pm
As an owner of a Studio maintenance, we get the upgrades.
Right now, we can't upgrade to version 9 as it would break our build process using FinalBuilder.
So it's a show stopper for us.
kwco
Postby kwco » Mon Jun 08, 2009 10:37 am
At least you can use the previous version. We evaluated Version 8 but bought Version 9. Our automated builds were dead on arrival.
Postby MichaelNesmith » Mon Jun 08, 2009 2:17 pm
Why not just let the build tool receive window messages?
kwco
Postby kwco » Mon Jun 08, 2009 6:57 pm
That is the solution. However, in order to do that, you need to have a user account logged onto the machine if you are running it from the windows task scheduler on Vista or Windows 2008.
It also means that it can't be run in an automated build tool that works as a background process. Instead of running as a service under the system account (or from a task as above) a build tool must run as a console app in a command prompt window to use miabuild.exe.
As other posters on this thread have noted, this makes it very inconvenient to use with automated build tools like Final Builder, Team City, Ant Build or Cruise Control.
Some IT departments won't leave accounts permanently logged on for security reasons and with that policy in place this issue is a show stopper that effectively makes automated builds impossible (at least it does for us). Daily builds that were scheduled for 4am now can't occur until 9 am when I arrive at work, log into the server and manually start them from the command prompt.
Users browsing this forum: No registered users and 35 guests
