Eval Plugin
zchris
Eval Plugin
Postby zchris » Mon Mar 14, 2005 12:12 pm
I've created a plugin to do simple boolean evaluations because the built in if command only let's me make one comparision at a time.
E.g. I can now write:
Eval DoUninstall = $NEEDSUPGRADE$="TRUE" or $FoundOldMsi$<>""
instead of:
Set Variable DoUninstall to FALSE
If Variable NEEDSUPGRADE Equals TRUE
  Set Variable DoUninstall to TRUE
If Variable FoundOldMsi not Equals
I've put this plugin together with the EditFile plugin into a new setup which you can download here:
The plugins are small and don't have any runtime dependencies.
disclaimer: you are free to use this plugin for any purpose at your own risk.
Sinan: you may of course host this one on your site too.
sinan
Postby sinan » Tue Mar 15, 2005 7:38 am
Thanks - this is wonderful :D
File mirrored at http://www.installaware.com/Camelot-Ins ... lugins.exe
If you installed the previous version - no need to manually remove it, the new installer automatically removes it for you - great job :D
zchris
Postby zchris » Tue Mar 15, 2005 2:16 pm
Actually InstallAware makes it so easy to create plugins that I just couldn't resist. The hardest part (as you can see from one of my previous posts) was finding the docs :D
