Is it possible to install the same source file into multiple locations on the target?
For example
I have file X that I want installed into $TARGETDIR$\\folder1 and $TARGETDIR$\\folder2.
Currently I do do this by making multiple calls to Install Files but I think multiple copies of the same file are copied into the installation resulting in a large installation size.
Thanks for any help
installing same file into multiple locations
You are right. If you install a file more then once, (in different folders), the file is copied that number of times in the installer. Here is a workaround:
Include the files as Support files or File Bag them and use the "Copy/Move Local Files" command to copy the files to all the locations you want.
Alejandro Ronquillo
Users browsing this forum: No registered users and 118 guests
