Debugger/Variable problem
Tinus
Postby Tinus » Thu Jun 29, 2006 5:30 am
in a Win32 project, I added these variables to the watch window:
SUCCESS
REMOVEOLD
LASTERROR
Then I stepped through. On a first time install all seems as expected.
But if a previous version has to be uninstalled I get some strange results.
Before
Install/Remove MSI Package $PRODUCTCODE$[REMOVE=ALL] (get result into variable REMOVEOLD)
gets called, SUCCESS is undefined, REMOVEOLD and LASTERROR are empty.
After the call I get
SUCCESS=ERROROLD
REMOVEOLD=SUCCESS
LASTERROR=
And then SUCCESS will never change and keeps the ERROROLD value.
Any assignment (like Apply Install) has no effect.
Is this a problem of the IDE/Debugger or of the runtime engine?
Martin Rothschink
AxoNet Software GmbH
Postby MichaelNesmith » Thu Jun 29, 2006 6:08 am
SUCCESS is probably not defined yet in your project - is this the case?
Tinus
Postby Tinus » Thu Jun 29, 2006 7:18 am
Yes, at that place SUCCESS is not defined (it's a standard Win32 template project) and the
debugger watch window shows correctly "Variable not defined". But after that call SUCCESS is
displayed with ERROROLD! Other undefined variables get not changed in this way.
I noticed this because I first had one breakpoint at Apply Install and tried to reuse SUCCESS.
Everytime I had to uninstall my previous version SUCCESS showed ERROROLD and
didn't changed any more. So I started to step through to find the call with this return value!
I assume that it is a problem of the integrated debugger/watch window. The runtime debug
command shows that SUCCESS changes and behaves as expected. But the debugger still
shows ERROROLD and some times REPAIR.
And a final problem: After a couple of debug sessions (3-4) I get an runtime error in Script:
Line 681: Unable to obtain command headers, rebuild project.
Then I rebuild and a couple of debug sessions later... :(
Martin Rothschink
Postby MichaelNesmith » Thu Jun 29, 2006 10:07 am
Hi Martin,
I'll log the issue with the variable.
As for the other error - this is normal. When you get this error, it means you have to rebuild your project, because the MSI has fallen out of sync with the editor code.
Users browsing this forum: No registered users and 46 guests
