I have existing projects that were working fine with authenticode. I updated my development machine (in place) from Vista x64 to Win7 x64, nothing else has changed, though I did also update the HDD (imaged the drive onto a larger HDD). All the same certificate files, same paths, same exact project, but now the authenticode signing always fails. I had to re-install IA to get merge modules working again; I've had this problem after MS updates sometimes as well but that is straight forward.
Can you think of anything I can do to try to get the authenticode working? Just in case I re-added these certificates locally to the trusted root certificate store (rather than any default path, but I've tried that also), that didn't make any difference.
And of course we need to get two installs out this week
My only backup plan would be to create some sort of virtual machine with an older OS and build it on that but it seems like others are not having this problem with Win7 x64?
