rename a file
bRIanG
rename a file
Post by bRIanG »
I have some problems copying/rename a file..
I have a AppName.Core_setup.config that I want to rename to AppName.Core.config, no rename function so I use the move function. But it does not work...
The file , AppName.Core_setup.config, is getting installed and is there in the targetdir when finished
~InstallAware Clipboard Data~
~Copy/Move Local Files~
~{C50F5D90-4045-4C46-8B26-717B89B9A4A7}~
~$TARGETDIR$~
~AppName.Core_setup.config~
~$TARGETDIR$~
~AppName.Core.config~
~FALSE~
~TRUE|FALSE~
bRIanG
Re: rename a file
Post by bRIanG »
So after putting it after apply install, it did rename that file, welll it ddid make a copy but it did not move it...
giaviv
Re: rename a file
Post by giaviv »
Dear bRIanG,
Try using the Delete command to make sure the original file is gone.
