How to create an installation that doesn't uninstall previous version and allow reinstalling on different target folders
kimatunit4
Postby kimatunit4 » Tue Jul 20, 2021 6:33 am
I have a standard client installation and wonder what would be the simplest/best way to transform it so the same installation can be installed concurrently on the same machine but in different target folders.
Or if there is some better way to do it than to modify the script to skip uninstalling previous version etc.
To have entry to uninstall for each installation is not required. Just entry which works for the last installed is ok.
The reason is because the new requirement to have a server installation for a native client application. And that server should provide access to the application to different customers using virtual desktop/application server.
Best regards,
Kim
Re: How to create an installation that doesn't uninstall previous version and allow reinstalling on different target fol
Postby FrancescoT » Tue Jul 20, 2021 4:40 pm
kimatunit4
Postby kimatunit4 » Sat Oct 09, 2021 2:17 am
Hi Franscesco,
Sorry for being late with the reply.
Thanks for the information. We will evaluate both your suggestions.
Best regards,
Kim
Users browsing this forum: No registered users and 131 guests
