Crash when installing Java
sjgilbertz
Postby sjgilbertz » Sat Jun 30, 2012 10:10 am
Hello, I'm an absolute newbie playing with Installaware Express for the first time today.
I used the Java Setup template to wrap a single java class file.
All seemed well and easy until I tried to run the installer.
It said:
"The following java requirements must be processed before starting setup:
Java Platform, Standard Edition 6, Update 25"
I clicked "Next"
A popup said
"A newer version of Java is already installed"
I clicked "OK"
A popup said
"Java Platform, Standard Edition 6, Update 25 installation has failed,
Fatal error during installation
Test1 setup cannot continue."
I click "OK" and the installation has stopped.
Suddenly things don't look so simple any more and I have no clue where to go from here.
Any help would be appreciated.
We really want to buy your product to install a java program as a service, but I need to see it working first :)
-- Steve
Re: Crash when installing Java
Postby FrancescoT » Mon Jul 02, 2012 5:29 am
Dear Steve,
the templete you used by default tries to install Java runtime Standard Edition 6, Update 25.
If this is not found (the verification is done by reading a System Reg Key), the installer executes the runtime installation.
Anyway seems in your case, that the setup tries to install the runtime even with a newer version is already present.
In order to verify correctly your issue,
- which is the runtime version already installed on your target machine (if any)?
- which OS are you using to test the package?
Let me know.
sjgilbertz
Postby sjgilbertz » Wed Jul 04, 2012 5:12 am
I have Java 6 Standard Edition Update 27 already installed
The OS is Windows 7 Pro SP1 (64-bit).
-- Steve
Postby FrancescoT » Wed Jul 04, 2012 9:52 am
Dear Steve,
I have tried to download the java runtime version you are using to execute a test, but I found problem trying to register on Oracle site.
Is it possible for you to send me the runtime package version (Java 6 Standard Edition Update 27 ) you used?
If you prefer you can sent it by email at: support@installaware.com
Once received I can try to give you a sample project.
Let me know.
Return to “Non-Technical”
