Sorry, I thought you were just talking about by following your instructions. I downloaded Patch.rar. I was able to successfully build them. The patch that got generated was larger than the original installer, but it did build. The original installer was pretty small to begin with though.
I see in your patch project it's completely separate paths to the executables. Is that required? Do I need to go and modify my patch project to remove all of the files that are not being changed from the project and put the modified files in a separate path?
Need help - Patch builds are HUGE
Re: Need help - Patch builds are HUGE
Dear Diablosport,
the patch that gets generated by the sample, it's smaller than the original base project used as reference.
The original setup exe is about 3,05 MB (3.201.482 byte) while the patch is about 2,40 MB (2.523.049 byte).
The sample uses separate source paths to clearly illustrate which are the effective files involved with each project.
You should use a similar approach in order to easily manage in the your setup projects, the different files and their respective versions.
The base project sample installs the following files;
Install Files ..\appfiles\1.0.0.0\TestApp.exe to $TARGETDIR$
Install Files ..\appfiles\1.0.0.0\dummy.dll to $TARGETDIR$
Install Files ..\appfiles\1.0.0.0\the file.pdf to $TARGETDIR$
while the patch project sample;
Install Files ..\appfiles\1.0.1.0\dummy.dll to $TARGETDIR$
Install Files ..\appfiles\1.0.1.0\the file.pdf to $TARGETDIR$
Then when the patch gets created, this will just include the binary delta difference of the updated files. In this case "..\appfiles\1.0.1.0\dummy.dll" and "..\appfiles\1.0.1.0\the file.pdf". While the file "..\appfiles\1.0.0.0\TestApp.exe" will be skipped by the patch generation, because it's identical in both projects.
