I was having a similar issue. Following advice in this thread I wrapped my Copy into enabling then disabling the native engine. Sure enough that fixed it. Why does this work?
Also Is there a way to overwrite the file if it exists without the prompt?
Copy OR Move Commands
Re: Copy OR Move Commands
Dear Francesco Toscano & Bokkie,
Hope you are doing Great !
Hey, using NATIVE_ENGINE is causing some problem...
You have suggested me following solution for copying files.....
if Variable SUCCESS Equals COMPLETE
Copy Local Files $LiccenseFilePath$\$LicenseFileName$ to $TARGETDIR$\$LicenseFileName$
After using NATIVE_ENGINE, Copying files is fine.
But Uninstallation is NOT WORKING.
surprised, it was hard to actually pin point the problem(I had other changes as well).
Yes, It is this particular statement which is causing Uninstallation problem.
Problem description:
I installed my program, everything is fine.
Uninstall thro' start menu short cut, looking OK, Got a message saying uninstallation is successful.
but short cut & All the files were intact.
then click uninstall link again on the start menu.
it asked me to select the proper file (Note: first time it won't ask - Obvious ).
I selected the proper file.
Uninstallation is successful. This time all the files were removed.
Appreciate your suggestion.
SITL
SITL
Dear SITL,
of course those files are NOT removed when uninstalling. Those operations executed under Native Engine are not included with the MSI database and consequently, the MSI engine cannot handle these when uninstalling.
To solve your problem, you may use the following approach just after your Apply Uninstall command;
In case you need to delete the TARGETDIR also (it must be an empty folder), you may use the approach described by the following link.
http://www.installaware.com/forum/viewtopic.php?f=2&t=10457&hilit=+RemoveDirectory
Apply Uninstall (get result into variable SUCCESS)
Delete Files $TARGETDIR$\$LicenseFileName$
Dear Francesco Toscano,
Thanks for your reply.
Your advice -
This won't work as expected, Registry cleanup won't happen, Sub folders & Short cuts will remain.
more details later . . ( I have other point to clarify )
So, Let me bring up my earlier post - ( i want to understand )
STEP 1> I installed my program, everything is fine.
STEP 2> Uninstall thro' start menu short cut, looking OK, Got a message saying uninstallation is successful.
STEP 3> Then click uninstall link again on the start menu.
STEP 4> It asked me to select the proper file (Note: first time it won't ask - Obvious ).
STEP 5> I selected the proper file.
My question is,How is it possible ?
When i ran the uninstall second time, everything is cleaned properly.Even the files copied by enabling NATIVE_ENGINE are also deleted.
Appreciate your advice
SITL
Your advice -
SITL
Dear SITL,
I can only suppose that there is something wrong with your script. Probably some commands are not sequenced correctly, but it's quite difficult to identify the error without having your files.
If you have any change to post a very minimal project that replicates the issue, I'll try to have a look.
Thanks for your suggestion.
It worked, I had deleted some statements
Bye
SITL
Bye
SITL
Users browsing this forum: No registered users and 43 guests
