Windows Firewall Plug-In
JamesB
Re: Windows Firewall Plug-In
Postby JamesB » Thu Aug 25, 2011 12:35 pm
Hello
First off - great plugin :-)
I wonder if anyone can help with a problem I'm having with it, tho - adding a firewall exception to WindowsXP SP2 when the exe is on another computer at the end of a UNC path. This doesn't seem to work.
In the program field I have: $SETUPPATH$\myprog.exe
And the setup is being run from a network location, with myprog.exe in the same folder.
If I display $SETUPPATH$\myprog.exe in a dialog, the result is:
\\JBPC\setupshare\myprog.exe
...so that seems to be correct.
Thanks in advance for any help.
James
Tinus
Postby Tinus » Thu Sep 01, 2011 8:09 am
This bug has been fixed. Please download again and install the updated version.
Martin Rothschink
AxoNet Software GmbH
SteveDude
Postby SteveDude » Thu Jan 19, 2012 4:11 pm
SPAM...what a waste of time. Whomever is doing it, get a life.
Bjarne
Postby Bjarne » Tue Jan 08, 2013 8:37 am
Hi, I'm running the Firewall Plugin 2.2.0.22 ( the version listed in Program/Features) , IA 15 and have problem removing the exception in Win7 Ent x64.
I'm trying to remove three exceptions which all were successfully added during installation.
The removal consists of two "delete allowed program" and one "delete port opening".
The "delete port opening" exception is removed successfully but the two others aren't.
Any ideas?
/Bjarne
Tinus
Postby Tinus » Tue Jan 08, 2013 9:17 am
Have these been created by the plug-in? Are the paths correct for the "delete allowed program" action (i.e. short names versus long names)?
Martin Rothschink
Bjarne
Postby Bjarne » Tue Jan 15, 2013 2:58 pm
Yes, all three. And all exceptions works.
Yep, checked and verified.
mikKummerfeld
Postby mikKummerfeld » Tue Mar 19, 2013 3:07 am
This plugin creates only incoming rules, not outgoing rules...??Why
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Tinus
Postby Tinus » Fri Apr 15, 2016 8:28 am
We will soon release a new Plug-In called Windows Advanced Firewall!
This will also create outgoing rules.
Martin Rothschink
Tinus
Postby Tinus » Mon Aug 29, 2016 7:37 am
Here is Windows Advanced Firewall:
viewtopic.php?f=3&t=10639
Martin Rothschink
Users browsing this forum: No registered users and 72 guests
