Keep the folder Name where ever you install the application
Doron
Keep the install folder name
Postby Doron » Thu Mar 15, 2007 9:21 am
Hi Andy,
Well the user never sees the C:\\Program Files as default he/she sees it as C:\\ABC
Then when they select any sub folder the ABC will go under it as D:\\MySub\\ABC
You did something similar and it worked but the difference is that above is trying to be installed under a sub folder as well. :)
http://forums.installaware.com/viewtopic.php?t=1894
If that can not be implemented as of now maybe the team of InstallWare can provide this kind of solution as well in the up coming update.
I would like to know if that is feasible?
Doron
Users browsing this forum: No registered users and 52 guests
