It's not as simple as editing text in the zip exe, or in the files contained within the zipped file. The caption text is either added dynamically, or the exe is compressed, but it's not just plain text.
Oddly, if they made it available as plain text, I would guess that about 85% of the people would just leave it there because they don't really care. It would seem like a simple option for them while keeping the majority of its "advertising" value, while people like me could change it if necessary.
Removing \" - InstallAware Wizard\" in the window title ?
you are assuming the obvious by thinking the name is not in one place ... but in fact this is what is so funny to me about this topic ... a well placed null character in interop\\miastub.exe before a build is all that is needed ... but of course you can't actually do this because you are not licensed for this ...
I'm not assuming anything, and not at all against making modifications for "testing" purposes. I think perhaps you may be making some assumptions about how easy it is to remove the "InstallAware Wizard" part of the caption while leaving my intended caption in place. If you've actually done this with InstallAware and know how to make a change, I would be genuinely interested in learning more about how to do it.
wileywilly
I have a workaround although its not perfect
One could set the variable $TITLE$ as your setup name then press on backspace so that you have alot of empty space before the - Installaware Wizard can show(see IA_Title).
IA will truncate the title so that if the '- Installaware Wizard' part will not show.
However, because the title was truncated,you will see '...' right at the far end of the title bar.
Not really professional but it gets rid of the '- Installaware Wizard'
[/img]
[/img]
wileywilly
Re: Removing \" - InstallAware Wizard\" in the window title
May I ask if we have an option of removing IA branding, for those not wishing to have it as part of the setup.
I saw a different post discussing the same thing titled:
Getting rid of \" - InstallAware Wizard\" in window Title
Please let us know if this planned for atleast the ADMIN version of IA.
