CAB files
giaviv
Re: CAB files
Post by giaviv »
Actually you don't need the Extract 7Zip Archive command - any content that is used inside a Web Media Block (such as files used in Install Files etc.) is automatically put in to the block (the 7zip archive) and is AUTOMATICALLY extracted for you at runtime.
loganlehman
Re: CAB files
Post by loganlehman »
But is it installed into the correct Target Directory location? Where do I specify that specific location?
giaviv
Re: CAB files
Post by giaviv »
You just use the normal file installation commands (such as Install Files).
Any files that are used in these commands are automatically added to the 7z archive and later extracted in a seamless process.
loganlehman
Re: CAB files
Great, this helps tremendously.
Is there any way to set a password on those generated 7zip files where only InstallAware can access them?
giaviv
Re: CAB files
Post by giaviv »
Yes - take a look at the Web Media Block command dialog - there is a password field there.
