Web update, empty description field
DariuszKalita
Post by DariuszKalita »
Hi Bar_BQ,
I tried it out - but without success in my case :( . I'll wait for the hotfix.
But anyway, thank you for your tip!
Rgds,
Dariusz
Don't wait! Its already live - regenerate and reinstall your license.
DariuszKalita
Hi Michael,
OK, the bug is fixed! It works fine :) .
Thank you for your support.
Rgds,
Dariusz
ALive
Post by ALive »
Hi!
That's exact the same issue i've encountered when building Russian localized setup. Just add localizations and Complex controls like Memo, RichEdit, ListBox, anything that has Lines property, does not show the localized strings. There's only one Caret Return symbol in the RichEdit or Memo control.
Btw, i've found a slight work around of this. If you supply Write Variable for the control, you'll be able to see the text. But the worst thing, that the user can accidentally erase the text (for example License Agreement), and that would be not good.
The issue could be reproduced in 8.01, 9.0 versions. I hope 9.01 does not have it (waiting for the download completion).
Thanks in advance!
