Would you be able to attach or link to your problematic installer?
I'd like to try installing it on one of my test environments to see if it will uninstall properly to see if it's a problem with the install itself or with the system you're working/testing with...
Uninstall from control panel fails
Re: Uninstall from control panel fails
I actually dont have a copy of it that will build at the moment. As i mentioned I rearranged the build process of my VS solution so the old installer woulndt even build at this point (without a fair amount of work) and i no longer have a copy of it. Also it's got proprietary software that does not belong to us so i'm not sure how comfortable our client would be with that . In any event we observed this problem on a number of systems, my dev machine, several VMs i've built, as well as on the client's machine. We used 32 and 64 bit versions of XP and 7. I believe the problem occurred on all of them. Either way it was not limited to just my development machine. If i see it happen again ill try to upload some stuff without any proprietary material, but right now i just don't have the time; we need to get some product out the door very soon.
