Unable to compile MSI action install assembly
giaviv
Re: Unable to compile MSI action install assembly
Postby giaviv » Wed Jun 01, 2011 1:16 pm
In that case you mush have an Install Assembly command somewhere in your MSIcode that is not reflected in the assembly view.
You can use CTRL + F to search for that command(s). Let me know what you find.
buffie
Postby buffie » Tue Jun 07, 2011 10:07 am
Sorry this took so long. I just finally saw that there was a page 2 to this thread. I did a search of the msi code of Install Assembly with no match case and Found Nothing????
Boy am I frustrated.
giaviv
Postby giaviv » Tue Jun 07, 2011 4:45 pm
Cam you please send the project to support at installaware.com?
Thank you!
buffie
Postby buffie » Wed Jun 08, 2011 1:47 pm
Do I zip it or how do I send it?
giaviv
Postby giaviv » Wed Jun 08, 2011 3:12 pm
Yep. Just put it in a zip file and send it on over.
buffie
Postby buffie » Wed Jun 15, 2011 10:49 am
You sent me a note about reinstalling and I did all of that. But, what I think fixed the problem was that I ran your software as an administrator and it worked? Could that be possible?
giaviv
Postby giaviv » Wed Jun 15, 2011 11:34 am
Anything can be possible! :)
ANders2020
Postby ANders2020 » Wed Aug 03, 2011 3:10 am
The Solution is to delete the relevant [install assembly ...] directives in <INstallAutoGen> in <MSICODe> main tab.
I found this out after a lot of fiddling and these entries remain even if the assemblies dialog is empty.
These entries are created when you generete the project from a Visual Studio Solution.
Even a search of [install assembly] will not come up with anything because you will most likely be in the <Your Project> tab under <MSICode>. And the search is limited to the current active tab. At least there should be search across entire solution.
Users browsing this forum: No registered users and 107 guests
