Install Splash Screen
erausner
Re: Install Splash Screen
Post by erausner »
It seems as if the "... is verifying..." text does not show up in neither the string resources nor the dialog. Could it be that the caption of the dialog is set by hardcoded value through the application logic?
if you are referring to the string;
"The InstallAware Wizard is verifying the contents of this setup package. This may take a moment."
This one is part of "InstallAware Shared Strings" (under "initialization text" section) and it can be replaced as you prefer
Please have a look at the quick tutorial "Translation Tool" available with the following link;
http://www.installaware.com/forum/viewt ... 72&start=0
