IA-2012 Cmd-Line ERROR Run IA-9 Project - MSI DB Init Fail?
giaviv
Re: IA-2012 Cmd-Line ERROR Run IA-9 Project - MSI DB Init Fa
Post by giaviv »
Interesting! My output is attached below.
Please try regenerating your license online, reinstalling IA and re-applying your newly generated license.
C:\BasicSetup>"\Program Files (x86)\InstallAware\InstallAware 2012\miabuild.exe"
 BasicSetup.mpr
 M     M  SSSSSS  IIIIII
 MM   MM  SS        II
 M M M M  SSSSSS    II    InstallAware with InstallAware DRM
 M  M  M      SS    II
 M     M  SSSSSS  IIIIII
InstallAware MSIcode Compiler (Moooya) "Join the GlaB Revolution!"
Copyright(C) 1996-2012 InstallAware Software. All rights reserved.
Building Project: BasicSetup
Output Folder: C:\BasicSetup\Release\UncompressedDeployment Type: Uncompressed Directory Layout
Code Signing: Disabled
Compression: Best
Compiler Variables: BUILDMODE=CD,"LANGUAGE=English","TITLE=BasicSetup",TARGETDIR
=$TARGETDIR$,IADIR=C:\PROGRA~2\INSTAL~2\INSTAL~2,PROJDIR=C:\BASICS~1,IAVER=13.00
Cleared output folder C:\BasicSetup\Release\UncompressedBuilt plug-in action (Un)Install MSI Setup
Built installation executable
Injected setup languages
Compressing componentstree.dfm
Compressing destination.dfm
Compressing finish.dfm
Compressing finish.dfm.miaf
Compressing licensecheck.dfm
Compressing licensecheck.dfm.miaf
Compressing maintenance.dfm
Compressing prereq.dfm
Compressing progress.dfm
Compressing progressprereq.dfm
Compressing readme.dfm
Compressing registration.dfm
Compressing registration.dfm.miaf
Compressing registrationwithserial.dfm
Compressing registrationwithserial.dfm.miaf
Compressing setuptype.dfm
Compressing setuptype.dfm.miaf
Compressing startinstallation.dfm
Compressing startmenu.dfm
Compressing welcome.dfm
Compressing wizard.dfm
Compressing mMSIExec.dll
Injected runtime files
Build completed successfully
Bill Stephens
Post by Bill Stephens »
Hi Aviv. I regenerated my license, did a complete reinstall of IA12, this time with all options instead of custom install. It still doesn't build from the command line but does build from within the IDE. I'm downloading the Trial version now and will try it again. Thanks for your help!
Bill Stephens
More info that may offer clues...
If I open the project by double-clicking the .mpr file from Windows Explorer and then clicking the Build button, I get the error. If I then open the project from the Open Project folder icon and then click Build, it builds successfully.
giaviv
Post by giaviv »
Dear IA customers,
We seem to be unable to reproduce this issue in house. We are working directly with the OP to find out what the problem is (our guess is that it is specific to his machine).
We will keep all of you posted.
smndk
Post by smndk »
Hi
I am also experiencing this problem. Did you manage to find the cause?
I am now using InstallAware 11 again.
Kind regards,
Svend
giaviv
Post by giaviv »
We were never able to reproduce this issue in-house. Do you think you would be able to guide us to do so?
