Errors when installating if $ALLUSERS$ = FALSE
Doesn't the web media block get pulled again if files are not found when the web media block is re-declared at another section?
wolbrink
Post by wolbrink »
MichaelNesmith wrote:Doesn't the web media block get pulled again if files are not found when the web media block is re-declared at another section?
Not according to what I experience. And there lies the problem, IMHO.
May I request a minimum project that demonstrates this behavior?
wolbrink
Post by wolbrink »
MichaelNesmith wrote:May I request a minimum project that demonstrates this behavior?
See attached.
--Troy
<a href="files/051020062138/MinimalSetupProject.zip">MinimalSetupProject.zip
Thanks - I've escalated this, a resolution should be available soon.
