wait until (un)install msi command has finished
Re: wait until (un)install msi command has finished
Postby FrancescoT » Fri Jul 06, 2012 8:57 am
Dear Keefie,
so it should works without any problem.
Please can you contact me at: support@installaware.com
I will try to give you an access to upload your MSI ... if you still have problem
ElJi
Postby ElJi » Wed Oct 29, 2014 11:16 pm
Dear support, dear all,
i have the same problem with msi files generated by InstallAware Studio 15.
I start the setup.msi at a dos windows:
1) setup.msi
=> I get the prompt at once
2) start /wait msiexec.exe /i setup.msi
=> I get the prompt after answering the question from "User Account Control" dialog.
I want the get the prompt (= control) AFTER the setup.msi run is finished.
Are there any fixes or work-arounds please?
El Ji
Postby FrancescoT » Fri Oct 31, 2014 10:18 am
Dear El Ji,
What you are reporting is related to a different question.
unfortunately, (...instead) this is a know issue and currently, it doesn't exist a possible workaround to use in your case.
Users browsing this forum: No registered users and 96 guests
