Merge Module problems
IanM
Postby IanM » Thu Oct 27, 2005 8:24 am
sinan wrote:I'm really not sure about the standard MSMs...send us a download link, and we'll take a look at it.
MSXML4 MSMs
http://www.microsoft.com/downloads/deta ... laylang=en
MSXML3 SP5 MSMs
TIA,
Ian
sinan
Postby sinan » Thu Oct 27, 2005 9:03 am
I see there is an MSI file for MSXML3. I recommend you run that file using the (Un)Install MSI Setup plug-in command. You may add it to your project as a support file and execute the MSI using the path $SUPPORTDIR$\\msifile.msi.
sinan
Postby sinan » Thu Oct 27, 2005 10:06 am
Also, I was able to merge these fine. Is the merge module library still registered on your system?
IanM
Postby IanM » Thu Oct 27, 2005 10:27 am
sinan wrote:Also, I was able to merge these fine. Is the merge module library still registered on your system?
Very odd. I re-registered mergemod.dll in the InstallWare folder, but it still does not work for MSXML although the MS Soap merges work ok.
Don't worry any further - I can get around any issues with your suggestions.
Ian
Users browsing this forum: No registered users and 28 guests
