Register Assembly Issues
Thanks, I'll have this escalated and resolved.
Hi Matt,
Here is a new DLL for importing data from COM servers and .REG files.
You may place it in your InstallAware folder, overwriting the old copy of the DLL.
Imports that were previously not working should work correctly with this DLL. If there are still any issues, please let me know.
This is one of the fixes that are included in the upcoming update, but since its "modular", I thought I'd make it available here for you to try and make sure it works as desired, before going "public" with it.
Please let us know! Thanks...
RegOverride.dll
Also, if you can post the assemblies that fail with the Register Assembly command (or let me download them from somewhere), I'll be able to escalate the problem with that command as well.
skibbs
Post by skibbs »
MichaelNesmith wrote:Hi Matt,
<a href="files/0708200675/RegOverride.dll">RegOverride.dll
Thanks Michael!
The new DLL imports our .REG files flawlessly :D I really appreciate the uber-fast turnaround time on this bug fix. I am able to successfully import REGEDIT4 format .REG files that are exported by REGASM.
Thanks again!
Matt
You're very welcome, Matt!
