Filling a Listbox. How?
Re: Filling a Listbox. How?
Dear CNC,
That's correct!
to summarize and to be sure that I haven't missed anything, you still receive the "OnChange: Invalid property value" when editing the listbox content string via Dialog Editor. Correct?
CNC
Post by CNC »
FrancescoT wrote: to summarize and to be sure that I haven't missed anything, you still receive the "OnChange: Invalid property value" when editing the listbox content string via Dialog Editor. Correct?
Yes, exactly.
Dear CNC,
could you please try with using the attached sample?
I have replicated your exact configuration with a test machine and I am able to use the attached project correctly.
Let me know.
listbox.rar
(7.89 KiB) Downloaded 393 times
bokkie
Post by bokkie »
FrancescoT wrote:To Peter;
When the update only includes IDE fixes, it is just enough to run the regenerated license file to have the product updated.
Francesco, I usually always download the full setup and regenerate my licence file. Using the scenario you mentioned, how would I know for sure the licence file regeneration is all I need if the update is just to the IDE? I don't recall ever seeing anything that tells me the licence file is all that's necessary.
CNC
Post by CNC »
Francesco, I tried the sample project you provided. Otherwise it works fine, but I still get the same error when trying to change the Listbox Items-property. So no luck.
BUT
I can go around this problem in my development project by copying the listbox from your sample. Since it already has $LISTBOXVALUES$ assigned, I can just use that variable. :D
Dear CNC,
I happy that you are able to solve your issue using my sample as work-around, however I would like to find out what really happens.
can you please contact me at; [email protected]?
To Peter;
you are right and not all time this is reported with the fixes list.
Anyway, if you need to know ... just email me.
