SQL Server connection issues
anja_laenge
Re: SQL Server connection issues
Post by anja_laenge »
tzachk wrote: Developers are dependant on clear log messages from external liubraries they use. Installaware either need to provide clear explanation on the inner working of it's code logic or relevant log messages. If your SQL server plugin depends on SQL browser port availability, failed to connhect to it should popup a different log message then SQL server connect fail.
It seems there is no progress at all at this point.
