Error using miabuild.exe with MSBuild & Task Scheduler
kwco
Post by kwco »
How do I reset the update app? I had to cancel out of the 9.04 install (wrong user account) and now I can't get the update link to bring it back up again.
Just install the latest trial from the public website, and then re-generate and re-install your license from your private customer account site.
kwco
Post by kwco »
That's exactly what I did. I also ran my test build that recreated the problem from the 2008 task manger and it is now working. No unhandlled exceptions.
Good job. Thanks.
AH-NP
Post by AH-NP »
Everything works fine since the upgrade !
Thanks !
AH-NP
dmostert
Post by dmostert »
Weird - this problems seems to be fixed for other people, but I still get it? (even with 9.06)
My CC.Net server process runs as special user acount and not as the system account? Maybe this has something to do with the / my problem?
I need the special account to make my Delphi projects compile...
D.
The issue that has been fixed was that miabuild.exe required message processing, which broke its invocation from non-desktop interactive accounts.
You might be experiencing a totally different issue?
Mohamed Koker
Post by Mohamed Koker »
I am experiencing the same problem with InstallAware 9.06.
Is there any way for me to download InstallAware 9.04 to see if this version works?
Fortune passes everywhere
neillans
Post by neillans »
This bug has been confirmed as fixed in 9.06, please open a support ticket if you continue to see this error so that we can fully investigate.
Andy Neillans
