Reading a value from an XML
AdrianGray
Post by AdrianGray »
I am trying to read a value from a web.config file (XML format) as shown below. How do I retrieve the CURRENT_VERSION value with the file written in the following format. I am happy to get the whole "ADD" key and parse it. Get XML File Settings does not appear to work on this format and I am unable to find any examples of "Evaluate XPath Settings" which may help. I can read the entire file however I am hoping there is a better way. Thanks, Adrian.
<?xml version="1.0" encoding="UTF-8"?>
<configuration>
<appSettings>
<add key="DB" value="SQL"/>
<add key="ShowDefaultSettingUserMenu" value="False"/>
<add key="CURRENT_VERSION" value="2014.06.25" />
<add key="COMPANY_NAME" value="New School"/>
<add key="QuickLinkShowImage" value="false"/>
</appSettings>
</configuration>
AdrianGray
Re: Reading a value from an XML
I have managed to get the element by using XPath query //configuration/appSettings/add[@key="CURRENT_VERSION"] with the Result Type "Full XML String". Although this is great for reading it, I still have to parse the string to get the value attribute from it. Once done, I cannot re-write in a new value without reading in the file, then re-writing it. Is there a way to change an attribute of an element within an XML. Thanks, Adrian.
Dear Adrian,
Supposing you have;
<ApplicationSettings>
  <Section Name="General">
    <Key Name="RootPath" Value="C:\mytest\sales" />
    <Key Name="Images" Value="\Jpg\" />
  </Section>
  <Section Name="Connection">
    <Key Name="Server" Value="SERVER04" />
    <Key Name="SqlDatabase" Value="PM4Uster" />
    <Key Name="TrustedConnection" Value="0" />
  </Section>
  <Section Name="Agent">
    <Key Name="UseAgent" Value="0" />
  </Section>
  <Users>
    <key id="1" />
  </Users>
</ApplicationSettings>
To modify "<Key Name="UseAgent" Value="0" /> to <Key Name="UseAgent" Value="1111" /> :
~InstallAware Clipboard Data~
~Edit XML File~
~{E57A1E67-DE0C-4F73-A5CE-64F0739CC7D8}~
~C:\XMLFile2.xml~
~UTF-8~
~0~
~ApplicationSettings\Section\Key~
~"Name,UseAgent","Value,1111"~
~1~
~FALSE~
~FALSE~
~FALSE~
Hope this helps you
AdrianGray
I am not sure what I am doing wrong, however I have spent considerable time trying to get this to work without success. I have copied your solution and tried to modify it to match my file as posted above, without success. Are you able to see what I am doing wrong based on the file I have shown above. Thanks, Adrian.
~Edit XML File~
~{DB7DFCE4-FB67-454E-B34D-8ECB11F4711A}~
~$TARGETDIR$\TestWeb.config~
~UTF-8~
~0~
~configuration\appSettings\add~
~"Key,CURRENT_VERSION","Value,1111"~
~1~
~FALSE~
~FALSE~
~FALSE~
Dear Adrian,
... just a question, are you sure the XML file is effectively available on target system when you try to update it?
In other words, if the file is installed by your package, you should use the Edit XML File after "Apply Install" execution.
BTW, it seems you are using the correct parameters with command.
AdrianGray
The file I am testing against is in a fixed location and is not part of the installed files. I am just trying to read the key from it prior to installing other files. Can you please confirm if you are able to read the value from the file content I posted. Thanks, Adrian.
Please try with the attached project.
Xmltest.rar
(2.13 MiB) Downloaded 907 times
AdrianGray
Hi Francesco. Thanks for the sample project, however it did not work for me as it relies on knowing the original value within the "value=" attribute is in order to delete it. The situation I have is that I wish to replace the "ADD" element which has the attribute Key="CURRENT_VERSION" with a new value="NEW_VALUE", WITHOUT knowing what original value= was. It could be any number of values. To delete the key, it appears that you need to know what the "Value" already is, I do not. Without deleting it, the create/update does not appear to work for me. Is there a way to delete the "Add" element with the "CURRENT_VERSON" attribute without specifying its "Value" attribute. This is my issue. Thanks again, Adrian.
Dear Adrian,
if I haven't missed anything, I don't think is possible.
It looks impossible to identify such key ... it can be anything. Am I wrong?
AdrianGray
Hi Francesco. I can find it by doing the following...
~Evaluate XPath Query~
~{5AB84784-AC4C-4F19-84EF-CE95CE5C8ACB}~
~$TARGETDIR$\web.config~
~//configuration/appSettings/add[@key="CURRENT_VERSION"]~
~InstalledVersion~
~0~
This gives me the complete element into a variable (InstalledVersion). I then read the web.config file into a variable, parse it by finding <add key="CURRENT_VERSION", then parse the second part of the parse again to the first >
I then join the two halves of the file together but insert the new key between <add key="CURRENT_VERSION" value="2014.08.07" />. I then rewrite the file. I was hoping to PARSE the variable on with $InstalledVersion$ but adding a variable in the parse statement didn't work for me. This seems like a long way to update an XML file's element whereby I just want to insert a new date into the value=" attribute of it. Thanks for your ongoing help, Adrian
Dear Adrian,
with the complete element into a variable, are you not able to extract the element name (... via Parse String) that could be used with the Edit XML command to update the Key?
gibbie99
Post by gibbie99 »
This is probably not ideal to parse the string if you dont have to. this works. Basically pull in the attribute @value then under result type use node value.
~MessageBox~
~{4D9F8B1B-AA2F-448A-A504-C81D683C5D3A}~
~port is $PORTONE$~
~0~
~1~
~{1B70793D-F1BF-473C-87C3-31CEE8E810FA}~
~c:\neil.xml~
~//configuration/appSettings/add[@key="Topology.Server.Port"]/@value~
~PORTONE~
~2~
