Insufficient Memory
Andrew Brent
Insufficient Memory
Postby Andrew Brent » Fri Apr 10, 2015 10:00 am
Hi
Can anyone else reproduce this?
I have a project that we regularly recompile to a new version. If I change the Product Version and then save the project and then compile the installer it does not complete but simply complains of insufficient memory. Close the project and reopen it and run the compile the project it works. Now change the Product Version again. Don't make any other changes!!! Save the project and then compile it .... same error. Close the project and reopen it and it will compile.
Surely by making such an insignificant change should not require the IDE to be closed before you can compile?
Cheers
Andrew
Andrew Brent
Designer Contracts Ltd
Visual Studio 2022 - DevExpress - InstallAware X15
Re: Insufficient Memory
Postby FrancescoT » Fri Apr 10, 2015 1:32 pm
Dear Andrew,
it's a problem that could happen sometimes and generally, when the system doesn't have a large amount of RAM mounted on board or when several concurrent processes are in use by the system when the build process is launched.
Generally in most of cases, it's just enough to repeat the build process once again without restarting the application.
Anyway, I'll send another note about the problem to our dev team.
Andrew Brent
Postby Andrew Brent » Mon Apr 13, 2015 4:34 pm
Thanks Francesco. Just for extra info mine is a 64 bit Windows 7 machine with 32GB of Ram. 707GB of fee disk space (900GB SSD). Any other info you need please let me know.
How do i get email notifications of replies to my posts?
Cheers
Andrew
Andrew Brent
Users browsing this forum: No registered users and 80 guests
