Error during build: List index out of bounds
Dandaman
Postby Dandaman » Wed May 27, 2015 1:45 am
Hi I just installed InstallAware trail and converted my InstallShield 2014 project.
I had to fix up variables from "xxx" to $xxx$ in the script which was fine.
But then when building i get the error message
Copied file C:\V7 Installer\Application exe Professional\Benchmark.exe
Error during build: List index out of bounds (2)
I can't see anywhere near the Benchmark.exe file in the script where there is a list that could be out of bounds.
Anyone had experience with this issue when converting form InstallShield?
Re: Error during build: List index out of bounds
Postby FrancescoT » Wed May 27, 2015 11:23 am
Dear Dandaman,
please check in your script code that all conditional statements are correctly handled (If/End, While/end ... and so on).
You may have inadvertently altered one or more of the conditional statement blocks in your code.
Dandaman
Postby Dandaman » Wed May 27, 2015 8:22 pm
Hi FrancescoT,
It looks like the issue was with the conversion of the file extensions from InstallShield.
I had two entrys for file extensions after I removed them the error did not come up any more.
When I removed them from my script it starting building.
On a side note, it has been building for a while now and the progress bar does not give me adequate feedback on how long it is going to take.
I am starting to think that its gone into an infinite loop. How long should the build process take?
Dandaman
Postby Dandaman » Wed May 27, 2015 10:47 pm
I had to cancel the build as it sat there for over 30 minutes.
After cancelling it still just sat there. I had to end its task.
Any ideas what would cause it to go inifi? Should I just reduce the compression?
Postby FrancescoT » Thu May 28, 2015 10:38 am
Dear Dandaman,
would it be possible for you to send me your project?
If you prefer, you can send the whole IA project folder as compressed archive to; support@installaware.com
Dandaman
Postby Dandaman » Thu May 28, 2015 6:33 pm
I sent over the project zipped up. Let me know if you need anything else from me.
Postby FrancescoT » Fri May 29, 2015 12:20 pm
Received and replied to you this morning.
Users browsing this forum: No registered users and 132 guests
