Branding Removal
anja_laenge
Branding Removal
Postby anja_laenge » Thu Aug 06, 2015 3:43 am
using XE3 the line
Set Variable MYAHLOGO to TRUE
does not seem to work anymore. The dialog at start show the InstallAware Logo and text.
The logo also appears in the SelectLanguage dialog.
What is the up-to-date solution for removing the branding?
Re: Branding Removal
Postby FrancescoT » Thu Aug 06, 2015 9:15 am
Dear Anja,
that pre-defined variable has nothing to do with the InstallAware logo.
"MYAHLOGO: Initially an empty string. Setting this variable to TRUE will hide the InstallAware Wizard text appended to setup dialog captions."
dig you add to the project a customized copy of "installaware.png" file to display your custom 32x32 PNG logo during setup initialization?
You can add your logo from "Creatives" page in IA IDE.
anja_laenge
Postby anja_laenge » Mon Aug 10, 2015 4:18 am
Okay, the InstallAware.png worked for the initialisation dialog.
How do I change the icon in the language selection dialog?
Postby FrancescoT » Mon Aug 10, 2015 12:37 pm
It's not possible to customize the "language selection dialog".
Unless you edit its resources using any resource editor - the file is dependent.exe in your InstallAware folder.
anja_laenge
Postby anja_laenge » Tue Aug 11, 2015 6:47 am
May I commit some feature requests for future versions?
- make all used icons configurable; default values are welcome
- make all used texts configurable; defaults are welcome
- say googbye to non configurable filenames like
-- license rtf
-- license<LANGUAGE>.rtf
-- index.html
- design the IDE help more detailed and elaborately. There is never too much information.
(include the details only mentioned in this forum; e.g. the help topic on displaying an index.html during installation lacks a few necessary steps)
- provide some more samples to demonstrate approaches for common use cases
- provide an Undo for visual dialog modifications
- provide the possibiliy to open more instances of the dialog editor to migrate adaptions from one project to another
Postby FrancescoT » Tue Aug 11, 2015 12:51 pm
Dear Anja,
Thanks for your suggestions and we will consider them for possible future product enhancements.
However I have some notes about.
- For what concerns the "language selection dialog", please consider that it's also possible to create a custom "selector dialog" to use in place of the default one.
Of course using this approach, you have also to handle the logic that stays behind the standard dialog. It's not difficult anyway.
- All used Icons are currently configurable (with the limited exception of the "language selection dialog"). Please also note that you can only assign a single Icon with each Windows Application. Even if the setup process uses different dialogs, all of them inherit the Icon from the one assigned to the main application process.
- All texts are already fully customizable (with the limited exception of the "language selection dialog").
- Non configurable file-names as those you listed are instead more easy to handle in this way. This due the fact that it's not possible to have multiple version of these files with different names. For example the "InstallAware.png" used to replace the logo; it's not possible to assign multiple "logo" and consequently, it's easier to not have the necessity to specify a Icon file name with each project.
- Of course any documentation can be improved, but I also believe that it's quite impossible to include anything. Also consider that some basic and common tasks should be at least already part of the developer's knowledge.
- For what concerns examples, it's quite impossible to cover any possible use of a setup process with the respective sample.
However we continuously update our sample list and currently, I am personally adding new samples each time is necessary.
Did you have a look at: http://www.installaware.com/forum/viewtopic.php?f=2&t=6772?
Users browsing this forum: No registered users and 69 guests
