Very strange this morning I when to started installaware and when it started the splash screen had X2 instead of X3. The icons still have X3 and the directory is also X3, when installaware starts I do not see the newer VM functions that X3 added that were there a few days ago.
X3 turned partially back to X2
Re: X3 turned partially back to X2
Dear Fab Ster,
did you use the correct license file to activate the product?
Yes the automatic upgrade upgraded to x3 and it was working fine as x3, Btw I just recently purchased x2
Dear FabSter,
X3 requires a specific license file to activate the product.
If you are eligible for the upgrade, (the grace period for a free successive major release upgrade, it's 90 days from purchase order), you can re-generate your personal license file to activate IA X3 from your personal account page.
Note!!
You must reinstall the product if you have already used a wrong license file.
Note!!
