HI... I will try to keep this succinct as possible.
I have users who had installed a prior version of my application with WISE.
I have an installation which will update their system now using IA.
When I create shortcuts (hoping to duplicate what they already have for uninstall purposes) I end up with a shortcut.lnk in both the users desktop and the public desktop... so it appears I have 2 sets of the same desktop shortcuts.
Wise created the original USER desktop shortcuts and Installaware creates the PUBLIC ones.
I figure I have 2 options but for now want to examine #2.
1. Delete the user desktop shortcuts during the IA install.
or
2. Change the IA $desktopdir$ to the users desktop location. Right now IA pointing to the public desktop.
If I choose to do #2.... HOW DO I GET THE DESKTOPDIR variable to show the users desktop location??
The code I have currently have in the IA routine related to DESKTOPDIR are shown below (both copy text and IA copy)
I am still new to IA and could really use some help.
George
*** Code below
Get Folder Location System->Desktop Directory into DESKTOPDIR (get for ALL users is NOT checked)
Read Registry Key HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders\Desktop into DESKTOPDIR
Create Shortcut $DESKTOPDIR$\Hurrtrak EMPro to $TARGETDIR$\hurrtrak.exe
OR
~InstallAware Clipboard Data~
~Get Folder Location~
~{CCEB9F18-4EF5-410E-B3FB-6DB2584B2AA6}~
~DESKTOPDIR~
~17~
~FALSE~
~Read Registry~
~{0874967A-C26E-4090-A5B3-849D1667A245}~
~DESKTOPDIR~
~1~
~Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders~
~Desktop~
~Create Shortcut~
~{A0B5DE4B-41B1-4A5D-8CA6-487859978166}~
~$TARGETDIR$\hurrtrak.exe|FALSE~
~Hurrtrak EMPro~
~$DESKTOPDIR$|FALSE~
~|FALSE~
~|FALSE~
~0|~
~0|~
Desktop Shortcut problem
Re: Desktop Shortcut problem
Dear George,
it's not full clear to me why you want to proceed in that way.
Why do you want to keep the other WISE installation? if this gets uninstalled you don't need to replace/delete the existing shortcut.
In addition, you should not alter a shortcut created by another installer. This may cause an error with that installer if you try later to uninstall the app.
Thanks for the advice.
I still have the following question.
How do I get the $DESKTOPDIR$ variable to show the users desktop location not the PUBLIC one?
The code for this variable in my script was shown in my original email.
Thanks...
George
Thanks...
George
Dear George,
the DESKTOPDIR should be retrieved as follow;
With the above snippet; if the the installation is executed PER-MACHINE (ALL-USERS), the "Get Common Folder Location" will attempt to obtain the location of the pre-defined folder that is shared by all users of the target system (Get for All Users = TRUE). Otherwise, the location of the pre-defined folder for the current user will be acquired (Get for All Users = FALSE).
if Variable ALLUSERS Equals TRUE
Get Common Folder Location System->Desktop Directory into DESKTOPDIR
else
~End~
~{D3E728CA-2945-4AD2-8BAE-4C3F78B56D86}~
~{FC0675C9-8D69-4AF5-835D-32AEBB6BA167}~
~DESKTOPDIR~
~17~
~FALSE~
~Set Variable~
~{21CE164A-2DB2-4210-89DE-695BDF554890}~
~SHORTCUTFOLDER~
~$SHORTCUTFILES$\$STARTMENU$~
~Else~
~{782C9E00-FB73-40A6-8E5C-94C7DD9A8D5E}~
~{3E0A1CD1-64CD-4404-8015-125FE0E67B1E}~
~DESKTOPDIR~
~17~
~TRUE~
~Set Variable~
~{CC19A143-B775-4C8B-B82F-67453D228546}~
~SHORTCUTFOLDER$MYAH$MYAH$FALSE~
~$SHORTCUTFILESALL$\$STARTMENU$~
~If~
~{ED9089CB-C5C8-425F-908A-EC38E615CA54}~
~ALLUSERS~
~0~
~TRUE~
~FALSE~
Create Shortcut $DESKTOPDIR$\MyApp to $TARGETDIR$\MyFile.Exe
~Create Shortcut~
~{C98D24AC-9867-48BD-9C96-1201FAAC985A}~
~$TARGETDIR$\MyFile.Exe|FALSE~
~MyApp~
~My Test app~
~|FALSE~
~|FALSE~
~0|~
I believe it will.
Thanks!
Thanks!
Users browsing this forum: Google [Bot] and 51 guests
