I use a custom plugin developed with .net bridge.
I used it with IDE, with release and patch based on it, no problem.
When i run same projects with command line build (for patching), it fail with address violation, at makecab.exe step.
What is the difference with ide patch build vs batch build?
batch patch build works great without plugin.
Plugin Access violation patch build (batch only?!)
Re: Plugin Access violation patch build (batch only?!)
Dear Damien,
there's no difference in reality, unless the Miabuild tool is installed on a different machine where the IDE is not available. In this case you may missed to install something required by your plugin.
Anyway, I suggest you to run your plugin in debug mode from Visual studio ... this is the only option in order to effectively isolate the issue.
Please Note, this topic has been moved to the appropriate "Plug-In Development" forum.
Thanks FrancescoT.
Ok I ll try to explore more in my plugin, but I am really surprised about the fact of it fail in command line build but not in InstallAware IDE.
It is a simple install of I.A, all on same machine etc.
So I was looking for differences between IDE patch build and command line patch build to understand what is wrong (it is the only difference, and all works without my plugin, so I did not fail on command line^^).
I also tried Release command line build, it works great with my plugin, and my plugin works. It only fails with command line patch, patch IDE works ...
Very very strange.
My IA build must be triggered by Jenkins, so IDE building is not an option
Very very strange.
...also verify that all it's correct with the command line parameters supplied by Jenkins. It may be possible that there is an error there.
Users browsing this forum: No registered users and 46 guests
