I'm seeing issue similar to one described in viewtopic.php?f=2&t=9431&p=34461&hilit=installation+package+out+of+sync#p34461
When the error occurs, a MSI log file is created in %TEMP% folder with following error:
Error 1731. The source installation package for the product XXXXX is out of sync with the client package. Try the installation again using a valid copy of the installation package XXXXX.msi'.
I'm curious how would I troubleshoot this. I checked MSI in \Windows\Installer folder and that seem OK. Do I need to check any specific registry to get location of MSI that get used during uninstall. Any help would be appreciated.
Regards,
Uninstall error 1731
Re: Uninstall error 1731
Dear MDA,
you may use the "WiLogUtl.exe" to analyze a msi log file.
This tool is included with Microsoft Windows SDK.
At any rate, this error normally means you are trying to update, reinstall or install an additional feature of a Windows Installer setup using a different version of the setup sources.
Users browsing this forum: No registered users and 141 guests
