File Copy Fails
SebSpiers
File Copy Fails
Postby SebSpiers » Fri Dec 23, 2016 7:16 am
So I have a very simple part of my installer which copies a file from one location to another.
Run Program C:\Windows\System32\copy.exe C:\Temp\applicationHost.config C:\Windows\System32\inetsrv\config\applicationHost.config /y (WAIT)
When I run this from an elevated command prompt, it works just fine, when it runs as part of the installer, it does nothing, it doesn't even error.
I've tried sending the output to a log file but it isn't generated when run from InstallAware, it is however when I run the same command from CMD.
Any ideas?
I'm not a developer, I just want to install things...
SebSpiers
Re: File Copy Fails
Postby SebSpiers » Fri Dec 23, 2016 7:55 am
I tried running this from within a batch file and found that it claims to have been successful, however the file has not been copied.
Installer code:
Run Program $SUPPORTDIR$\copy_IIS_config.bat  (WAIT)
Batch File Content:
copy C:\Temp\applicationHost.config C:\Windows\System32\inetsrv\config\applicationHost.config /y
pause
Output:
D:\Projects\SmartInstantIssuance2\Smart Instant Issuance>copy C:\Temp\applicationHost.config C:\Windows\System32\inetsrv\config\applicationHost.config /y
        1 file(s) copied.
D:\Projects\SmartInstantIssuance2\Smart Instant Issuance>pause
Press any key to continue . . .
Re: File Copy Fails
Postby FrancescoT » Fri Dec 23, 2016 11:19 am
Dear SebSpiers,
there may be several causes at the root of your issue.
A- First of all and if your target is a x64 system, please consider that by default any setup package runs as a native 32bit application. Due of this, any call that points to a system directory or to HKLM system registry, it will be redirected by the system to the respective x86 location.
In other words, trying to store something to; "C:\Windows\System32" this will be stored to "C:\Windows\SysWOW64" instead.
At such purpose you may force the installer to instruct a native x64 process using the "Set x64 - Native 64 bit Windows, ..." statement.
B- also consider that because you are trying to store a file under a system restricted area ("C:\Windows\System32"), the process requires full administrative privileges to be completed successfully.
C- even for "cmd.exe" you should consider the behavior that I described at point #A. If your target is a x64 system, there are two distinct versions of the "cmd.exe" (the cmd-exe embeds the DOS Copy command). The native x64 version is available under "system32" while the respective x86 Platform version is stored under "SysWOW64". Consequently if your setup runs as a native 32bit application, the one effectively used will be the respective x86 "cmd.exe" under "SysWOW64".
That said, you may try the following;
Set Variable SYS_DIR to
Get Folder Location System->System Directory into SYS_DIR
Run Program "$SYS_DIR$\cmd.exe" /c copy "C:\Temp\applicationHost.config" "$SYS_DIR$\inetsrv\config\applicationHost.config" /y (WAIT)
the same as above in "InstallAware Clipboard Data";
~InstallAware Clipboard Data~
~Comment~
~{FA49E179-57A1-4B32-B446-4F578588D9EB}~
~Set 64 Bit Mode~
~{8EE9F2EA-8C47-46DC-88CF-132D134353CF}~
~TRUE~
~FALSE~
~FALSE~
~Run Program~
~{31580F40-CDEA-4098-A876-1008DB8AA64E}~
~"$SYS_DIR$\cmd.exe"~
~TRUE~
~/c copy "C:\Temp\applicationHost.config" "$SYS_DIR$\inetsrv\config\applicationHost.config" /y~
~TRUE~
~Get Folder Location~
~{60723E82-FC27-4FD7-94E9-A95A38413FFA}~
~SYS_DIR~
~23~
~FALSE~
~Set Variable~
~{31424C06-0E45-4C33-829E-93C552F8A5F8}~
~SYS_DIR$MYAH$MYAH$FALSE~
~Comment~
~{F1142BD4-F34F-43F3-9E59-CD4437521131}~
~Set 64 Bit Mode~
~{08C518DB-FFC8-42CE-9E53-617714928A3D}~
~FALSE~
~FALSE~
~TRUE~
Alternatively and in place of the "CMD.EXE", you may use the IA "Copy/Move Local Files" command. Note this is a Windows Installer Command (PURPLE COMMANDS) and in order to execute it immediately, it's necessary to switch ON the InstallAware Native Engine.
Copy Local Files "C:\Temp" \applicationHost.config to "$SYS_DIR$\inetsrv\config"\applicationHost.config
~Set 64 Bit Mode~
~{8D5C21D0-3396-4D81-BE3E-75EB4627CCB3}~
~TRUE~
~FALSE~
~FALSE~
~Set Variable~
~{D9A2E9F2-7648-4F2E-AD54-3F406C4751FF}~
~NATIVE_ENGINE$MYAH$MYAH$FALSE~
~FALSE~
~Copy/Move Local Files~
~{7DB220A1-D8C3-4749-8ED4-A7CBE1E081EF}~
~"C:\Temp" ~
~applicationHost.config~
~"$SYS_DIR$\inetsrv\config"~
~TRUE~
~FALSE|FALSE~
~{0F9A8F89-2AB4-41CB-B97F-2E720D9ACB8A}~
~SYS_DIR~
~23~
~FALSE~
~Set Variable~
~{ED66B34F-E5B0-4751-B53C-36ACB6B0F8CC}~
~Comment~
~{1FFD47FD-23DF-4FDA-A30D-8C30AD3E9D8F}~
~Set Variable~
~{F8BCCBA9-40E3-45E7-9AC9-5CD32BAEFCC5}~
~TRUE~
~Set 64 Bit Mode~
~{D0535D7F-C13B-4351-BE12-D5B8FF009AF3}~
~FALSE~
~FALSE~
~TRUE~
Finally, some useful links;
https://www.installaware.com/forums/viewtopic.php?f=2&t=4603
https://www.installaware.com/forums/viewtopic.php?f=2&t=4338
SebSpiers
Re: File Copy Fails
Postby SebSpiers » Wed Dec 28, 2016 5:15 am
FRANCESCO! GENIUS!
You were correct, it was being redirected to C:\Windows\SysWOW64\inetsrv\Config despite me using an absolute path in the command line.
Resolved! Thank you!
Users browsing this forum: Google [Bot] and 71 guests
