As I want to install X6 and have limited space available I want to uninstall X5 before.
I tried several times but It hangs several minutes at the message "Unregistering InstallAware Add-In for VisualStudio 2015".
Then it finishes with the message "InstallAware Installation failed "General Setup failure". Please check your Settings and try again".
I checked the Settings used repair etc. without any success uninstalling.
How to proceed?
Unistall X5 fails
Re: Unistall X5 fails
Dear Horst,
this may be due a system corruption.
I suggest you to try with the following tool.
https://support.microsoft.com/en-us/help/17588/fix-problems-that-block-programs-from-being-installed-or-removed
hope this helps you.
Dear Francesco,
sorry did not work.
InstallAware is not in the list of programs to be uninstalled.
Do you have a GUID to enter in the "Not listed" field?
sorry did not work.
Users browsing this forum: No registered users and 316 guests
