Dear Francesco,
For checking whether the Drive is valid or not,
Here is some work around...
Set Variable MYSPACE to
Set Variable MYPATH to D:\TestPath
Set Variable MYPATH_PARSED to
Parse String $MYPATH$ into Variables MYPATH_PARSED and (Split at first occurrence of pattern)
Get Total Space on $MYPATH_PARSED$ into variable MYSPACE
MYSPACE is Zero for invalid drive.
I feel, it's simpler than calling a library function & parsing.
Appreciate your comment.
SITL
Check whether the Drive is valid or not ?
Re: Check whether the Drive is valid or not ?
Dear SITL,
you can even use your approach and then to consider "MYSPACE = 0" as an invalid drive. However, this only tells you if the specific target drive has space available and not if this exists.
