when launching my setup two progress bars pop up successively.
First a progress bar with my application icon. After that a second progress bar pops up with the Installaware Icon. How can I customize the Icon of this form?
Thank you in advance,
Boris
Remove Branding Icon while launching
Re: Remove Branding Icon while launching
Dear Boris,
did you include an "installAware.png" (32x32 PNG) containing your logo into the Creatives section of your project?
Hello Francesco,FrancescoT wrote:Dear Boris,
no I did not. It now looks the way it should. Thank you for resolving my issue
Regard
Boris
Happy you solved!
