I moved from a older version (11) to Installaware xe6. I can compile and build my setup project. However, if i run my setup following error occurs:
Runtime error in setup script:
Source file: updates
Line Number: 4
List index out of bounds (809)
If i look in my script code, there is only following line there:
if Variable CMDLINE Contains /updateedit:
Also if i run the debugger it stops at this line with this error message..
EDIT 2:
Hello, anybody out there? My whole deployment toolchain is crap at the moment. I can not deliver software..
EDIT 3:
-------- Buyed update and now nothing works anymore.. annoying..
