I'm using installAware Studio X7, and I'm unable to get the "Install Service" command to work. The command executes and produces no output at runtime, but my service isn't installed. The command I'm using looks like this:
Install Service #PROJ_ROOT#\release\MyService.exe to $TARGETDIR$ as My Service Name#PROJ_ROOT# is a compiler variable set to point at my build directory. $TARGETDIR$ is set to point at the target installation directory. MyService.EXE is installed with an "Install Files" command with the same parameters earlier in the script. All my other files are installed with similar Intall Files commands, so I know the $TARGETDIR$ and #PROJ_ROOT# symbols work just fine.
If I run an "sc create" command with the appropriate parameters, I have no problem installing my service.
How can I get collect error information from my InstallAware script in order to diagnose this problem?
