Include Script Being Skipped
Russell
Post by Russell »
Why would an include script not run? I'm stepping through the main script and it simply will not run - the statement after it is. Even with a breakpoint on the call to the include script the debugger bypasses it.
I've noticed some strange anomalous behavior like this before. What am I doing wrong?
Thank You,
Russ
glenharvy
Re: Include Script Being Skipped
Post by glenharvy »
I suggest checking the value of the variable with "EQUALS(Ignore Case)" rather than "Contains".
Russell
Post by Russell »
Thank you for the reply.
I noticed that and changed it, but that made no difference; it was still ignored. I moved the include script to another IF block and it ran fine.
This feels like a bug, but I don't know.
-Russ
