ASP.Net Core Read Registry
ngurram
Postby ngurram » Tue Jun 09, 2020 10:48 am
I am trying to use Read Registry for HKEY_LOCAL_MACHINE\SOFTWARE\dotnet\Setup\InstalledVersions\x64\sharedhost like below
Set Variable ASPNet to
Read Registry Key HKLM\SOFTWARE\dotnet\Setup\InstalledVersions\x64\sharedhost\Version into ASPNet
MessageBox: ReturnASPNet, $ASPNet$
But the return in the variable is always blank, even though I can see the registry for it on the box exists.
Has anyone else run into this issue? Help please?
Any help is much appreciated.
Re: ASP.Net Core Read Registry
Postby FrancescoT » Tue Jun 09, 2020 12:37 pm
Because I suppose you are checking such key on x64 target OS, are you switching to x64 mode before invoking the "Read Registry key" command?
ngurram
Postby ngurram » Tue Jun 09, 2020 3:15 pm
Thanks for the reply Francesco. Yes I am looking in x64 OS (Windows Server 2016 / 2019). I am not sure how I should switch to x64 mode though. Is this something to be done in IA?
ngurram
Postby ngurram » Tue Jun 09, 2020 7:26 pm
I Googled it and I think I got it working. For anyone else who may run into this issue, below seem to work for me.
Set x64 - Native 64 bit Windows, AMD64, EM64T, and ARM64 Architectures - installation mode
mdavtec
Postby mdavtec » Wed Apr 21, 2021 7:43 am
Don't forget to set the mode back to 32 bit after reading the registry
ExchA
Users browsing this forum: No registered users and 170 guests
